W204 C-klasse kombi instrument swap W212
anishramdas
Mercedes-Benz: W203 2003, W211 2004
05 feb 2012 22:29
Hee,
Is het mogelijk om zo'n instrument ook in een w203 te plaatsen (na wat aanpassingen)?
ALvast bedankt,
Anish
MBenzNL
05 feb 2012 22:40
anishramdas schreef:Is het mogelijk om zo'n instrument ook in een w203 te plaatsen (na wat aanpassingen)?
jawel...op de achterbank of in de kofferruimte ;) en dat gaat dan overigens ook zonder enige mate van aanpassing
Verwijderd13263
05 feb 2012 22:55
anishramdas schreef:Hee,
ALvast bedankt,
Anish
Een 209 klok kan er wel in Anish, heb er nog eentje over die je kan 'schoonvegen' bij de kilometerboer en inbouwen.
rainless
Mercedes-Benz: C320 CDI 4MATIC (2008)
06 feb 2012 17:37
Thank you, sounds good and thank you for the quick answer! So Star Diagnosis Developer it is. What exactly do you refer to as version coding? In other words, could I physically install this myself and then drive to somebody with the developer kit to have it matched to my individual cars features, or does it need to be programmed immediately?
Furthermore, is my understanding correct, that the gauge cluster must be new as the car will not accept one that had previously been mated to another vehicle? (Despite Mercedes themselves selling used clusters through MBGTC...)
P.S. The reason I came across this modification in the first place is because somebody in Germany was able to install the new W212 gauge cluster with the new color screen in a W204, which of course is the pinnacle of this change.
MBenzNL
06 feb 2012 21:49
rainless schreef:Furthermore, is my understanding correct, that the gauge cluster must be new as the car will not accept one that had previously been mated to another vehicle? (Despite Mercedes themselves selling used clusters through MBGTC...)
the cluster HAS to be new indeed...MBGTC sells new instrument clusters every now and then - but then again, they easily tell you that a certain IC is new even when it has done 5km (and has been assigned to a car already)
the new IC with colordisplay is most probably too new for DAS developer...incase you do want to go for a colordisplayed IC, I have a new C63 one in stock (which fits the pre modelupdate 204s as well after the front faceplate has been swapped out)
perdikoula888
11 mar 2012 14:33
How much for the new w204 c63 colordisplayed IC? Is it plug and play with my prefacelift w204 c250 after I swap the faceplate?
MBenzNL
11 mar 2012 18:52
perdikoula888 schreef:How much for the new w204 c63 colordisplayed IC? Is it plug and play with my prefacelift w204 c250 after I swap the faceplate?
probably not...DAS versions of stardiagnose won't be able to recognize the updated 212 cluster and the xentry version of stardiagnose won't let you versioncode it in a 204
perdikoula888
12 mar 2012 21:24
Does this apply even if it is an actual facelift w204 cluster rather than a w212? I thought that electronically it might be more compatible a facelift w204 IC even though it might require a prefacelift faceplate to physically fit the car. Am I correct?
Zeebaars1977+
25 mar 2023 14:23
Ziet er zeker mooi uit
De teller moet zeker wel ingeleerd worden
Maakt het uit als de teller voor een diesel en automaat is
Maar wel op een benzine handgeschakeld gemonteerd wordt
Ik hoor het graag
25 mar 2023 16:03
De toerenteller van een diesel en benzine zijn anders.
J82
Mercedes-Benz: S212
25 mar 2023 18:52
plorie schreef: 25 mar 2023 16:03 De toerenteller van een diesel en benzine zijn anders.
Als je een beetje rustig aan doet met je benzine merk je daar niets van. :P
Het gaat beter als je denkt! :goedzo:
hier vind je mijn S212 - E350cgi Avantgarde - 2010
Zeebaars1977+
27 mar 2023 19:11
Dank jongens
