Ik heb pas het abonnement op EPC verlengt /betaald en als ik nu inlog zie ik een nieuw venster maar geen knop meer met EPC. ik zie wel ergens EPC staan maar als ik daar op klik zie je dat de EPC is veranderd maar niet hoe en waar ik kan inloggen het gaat mij voornamelijk om een datakaart te kunnen inzien en printen.
Wie kan me helpen of wat doe ik verkeerd
Gr
Han
EPC Veranderd ????
- Sneaky Pete
Ik log normaal in via de MB-club portal en daar werkt EPC nog wel.
Maar ik krijg daar wel de volgende pop-up:
Most of you may be familiar with the Electronic Parts Catalogue (EPC for short), which is freely accessible to members of the officially recognised Mercedes-Benz brand clubs via our ClubLounge.
Daimler AG has decided to replace the EPC with the all-new XENTRY Portal for institutional users (branches, dealers, etc.) to ensure a streamlined, up-to-date offering for various different user groups around the world as we move forward. For individuals and other users the SAI-Portal was launched, including the ISP Parts Information as all new application replacing the EPC.
Following the successful launch of the XENTRY Portal during the course of the year, technical support for the predecessor EPC system can now no longer be maintained and the Electronic Parts Catalogue will be discontinued on 14.12.2018.
The EPC will therefore no longer be accessible via our ClubLounge starting 14.12.2018.
To ensure that you can access the new SAI-Portal for individuals in future, we are maintaining close contact with the respective specialist departments. Since the new system is subject to the latest legal regulations regarding data protection and security requirements, it is not possible to use the SAI-Portal via the ClubLounge without entering personal SAI-Portal registration and user login details as for the previous EPC offering.
This is why we are working hard on implementing personalised SAI-Portal registration for club members via our ClubLounge. The goal is to go online by the end of January 2019 with a corresponding SAI-Portal registration tool in the ClubLounge. All club members looking to use the SAI-Portal in future can sign up as users via the aforementioned registration tool. Personalised SAI-Portal access will be enabled starting in early February.
Kortom, met ingang van 14 december wordt EPC zoals het nu is beëindigd en omgezet in een versie apart voor dealers/autobedrijven en een versie voor simpele zielen zoals wii.
Daar zal het wel iets mee te maken hebben.
Alleen moet ik me als MB SLK club lid opnieuw registeren om toegang te krijgen tot de nieuwe versie van EPC. Lullig alleen is dat het tooltje waarmee je dat moet doen pas eind januari klaar is..........
Tot die tijd geen toegang dus en of ik daarna net zoals nu nog toegang tot WIS heb is ook maar afwachten. Not happy.......
Maar heb je geen mailtje oid gekregen?
In de VS zijn ze al bezig met omzetten en op het Engelstalige forum ston deze handleiding https://epc.startekinfo.com/epc/ISPPI_U ... USA-EN.pdf
Misschien kun je daar iets mee?
- motorhan
Ik zie dit
https://service-parts.mercedes-benz.com ... gin.action
Ik log daar in en voorheen stond er dan onder het inlogvakje EPC dat is weg en als ik klik op wat dan ook dan krijg ik onderstaande tekst.
Die Teileinformation ist das neue Teileermittlungssystem und löst das bestehende System EPC ab.
Ab 30.11.2018 wird die heutige Applikation EPC durch die Teileinformation ersetzt.
Die Teileinformation ist das neue Teileermittlungssystem für Ersatzteile, Lacke/Betriebsstoffe, Zubehörteile (sofern diese eine A-Sachnummer besitzen) und Werkstattausrüstung der Marken Mercedes-Benz und smart.
Die Teileinformation bietet den vertriebsnetzfremden Werkstätten einen vollständigen Ersatz des heutigen EPC. Damit stehen Ihnen eine Möglichkeit der Teilerecherche mit den folgenden Funktionalitäten zur Verfügung:
Zukunftsfähige, webbasierte Lösung für die Teileinformation
Moderne Oberfläche, einfach erweiterbar um neue Anforderungen
Aktueller Datenstand durch schnelle Publikation
Schnellere Korrektur und Aktualisierung der Teiledokumentation im Fehlerfall
Anzeige der aktuellsten Datenkarteninformationen
Bildorientierte Teilerecherche z.T. mit Graustufenbildern auf Basis 3D
Möglichkeit der Arbeit mit zwei Bildschirmen (Bildtafel und Liste) gleichzeitig
Verfügbarkeit Sparten: Mittels Teileinformation können Teile für die Fahrzeugsparten und Industrieaggregate (IAG) ermittelt werden
Maar ik kan er niks mee
gr
Han
gr
Han
Met vr gr
Log hier is in :
https://xentry-shop.mercedes-benz.com/d ... hop/home?0
En ja EPC is er uit en vervangen door dit RUK systeem .
En zijn op de links handleidingen die je door kunt nemen.
Je krijgt dan dit soort fratsen
- 127824B3-E13D-4254-A005-70E912684B04.png (169.36 KiB) 1870 keer bekeken
- Schroef
- Mercedes-Benz: W203/C180
Lekker geregeld van MB.
PSA gebruikt al jaren een web based interface waar je geen cent voor betaald en ook nog de prijzen erbij vermeld krijgt.
Mijn EPC abonnement is onlangs verlopen. Wilde niet verlengen voor alles duidelijk zou zijn. Maar nu blijkt dat wij simpele sleutelaars voorlopig geen duidelijkheid hebben.
Net aangemeld op de oude EPC, ik kreeg een popup met login site (https://aftersales.i.daimler.com), benutzer id en startpasswort.
Op de site daarna wel melding van technische problemen, aanmelden niet mogelijk...
Edit: aangemeld op de oude EPC waar ik doorverwezen werd naar de nieuwe. Ondertussen aangemeld, werkt goed, maar enkel met IE of Firefox, niet met chrome
Laatst gewijzigd door GeoffBE op 05 dec 2018 10:21, 1 keer totaal gewijzigd.
- motorhan
ElGriffo schreef:Log hier is in :
Dan krijg ik pasword of inlogcode niet correct/ dar word je dus niet vrolijk van. Weer een of andere Nono die vond dat er iets veranderd moest worden.
Met vr gr
Net nog ingelogd geweest via de Mercedes Clublounge
https://clublounge.mb-lounge.com/de/anmeldung.html
- motorhan
Ik heb een mail gestuurd via de contact en betaal link antwoord duurt meestal een aantal dagen we wachten maar geduldig af.
gr
Han
Met vr gr
- Frank DP
Net nog aangemeld in EPC, zonder problemen. Wel ook de melding gekregen en gelezen dat het vanaf 14/12/2018 off-line wordt gehaald.
Ik heb mij ingelogd via de MB CLublounge pagina, als lid van MB SLKclub NL. Vandaar misschien dat ik er nog op geraak?
Wat zijn de voordelen als men een betalende versie neemt?
Mvg,
Frank
Frank
Ik ook, via de S-klasse clublounge.
Het overkomt mij regelmatig dat alle keys bezet zijn en ik het later nog eens moet proberen. Het is een gedeelde inlog met alle clubleden, dus ook andermans VIN's zie je terug.
Dat je er altijd in kunt en je eigen chassisnrs. bewaard blijven.Frank DP schreef:Wat zijn de voordelen als men een betalende versie neemt?
- motorhan
Leuk dat het bij jullie wel werkt maar daar schiet ik natuurlijk nog niks mee op.
ik heb inmiddels een paar reacties ontvangen en 2 andere links maar als ik daar probeer in te loggen krijg ik te zien gebruikersnaam en of wachtwoord niet bekend. vervolgens weer reactie ik moet epc voor mijn gebruikersnaam zetten maar dan krijg ik weer wachtwoord klopt niet. en ze blijven zeggen je moet met hetzelfde wachtwoord inloggen.
Dan klik ik op wachtwoord vergeten en dan krijg ik weer kan niet neem contact op met je systeem beheerder.
Gewoon inloggen op de oude site werkt nog steeds kun je ook boven op de afbeelding zien. en ik kan veel aanklikken maar kom nergens iets tegen waar ik een chassisnummer kan ingeven om bij de datakaart te komen.
Het zal best aan mij liggen maar wordt er wel een beetje droevig van.
Net weer een reactie gehad stuur maar een bericht naar..... waar ik al 5x een bericht heb gepost Ja leuker kunnen ze het niet maken.
Gr
Han
Gr
Han
Met vr gr
- Frank DP
Bedankt Plorie, hoopte dat ik dan de prijzen zou kunnen zien....plorie schreef:Ik ook, via de S-klasse clublounge.Dat je er altijd in kunt en je eigen chassisnrs. bewaard blijven.Frank DP schreef:Wat zijn de voordelen als men een betalende versie neemt?
Mvg,
Frank
Frank
