Ik denk dat ik de app ga kopen want hij geeft veel nuttige info (zie hieronder).
Zijn er meer gebruikers?
Code: Selecteer alles
0. Motor Control:
FSCU - Fuel pump AMG (MB: 2215401762):
- Fault: This fault can be ignored and erased.
- Code: 00C100
Motor Electronics (MB: 0034460840):
- Fault: Malfunction of secondary air injection (function chain) (P0410)
- Code: 002003
1. ABS / DSC / Brake:
ABR - Adaptive Brake (MB: 2215455232):
ECU OK, no fault code
DTR - Distronic (MB: 2165400117):
EFB - Electric parking brake (A13) (MB: 2214300649):
SGR - Radar sensors control unit (MB: 0365451032):
- Fault: Component A86/1b3 (Right inner radar sensor, front bumper) is disrupted by interference from an external transmitter.
- Code: 005304
2. Airbag:
AB - Airbag (MB: 2218704887):
3. Transmission Control:
ETC - Electronic transmission control (MB: 0034464110):
4. Instrumentation:
COU [ZBE] - Central operating unit (MB: 2218212251):
OCP - Overhead control panel (MB: 2218704186):
RCM - Rear control module (MB: 2168207426):
- Fault: Rear right window position : Memory overrun while writing to EEPROM
- Code: 009266
IC - Instrument cluster (MB: 2215404011):
UCP - Upper control panel (MB: 2218701158):
5. Light/Rain Control:
XALWA-L - Xenon headlamp, left (MB: 2168203685):
XALWA-R - Xenon headlamp, right (MB: 2168203685):
6. Heating / AC:
AAC - Automatic air conditioning (MB: 2218709987):
7. Immobilizer System:
KG - KEYLESS GO (N69/5) (MB: 2215454432):
ASSYST Active Service System (MB: 2215408945):
ASSYST PLUS (MB: 2215408945):
9. Audio / Navigation / Communication:
ZAN - Central display (MB: 2218700489):
- Event: The supply voltage of the control unit is too low (undervoltage).
- Code: 00D010
COMAND (MB: 2168207085):
- Fault: The supply voltage is too high or too low.
- Code: 00D014
- Fault: The MOST network was shut down due to insufficient battery voltage.
- Code: 00D015
- Fault: MOST component at position 2 reports open ring.
- Code: 00D102
- Fault: MOST component at position 3 reports open ring.
- Code: 00D103
10. Systems:
BNS - Vehicle power supply control module (MB: 2215458232):
- Fault: The consumer shutoff is active.
- Code: 009014
ISM - Intelligent servo module (MB: 1642700352):
EZS - Electronic ignition switch (MB: 2215450708):
TLC - Trunk lid control (MB: 2218706487):
- Event: Control module N121 (TLC control module) has detected undervoltage.
- Code: 009010
SCM [MRM] - Steering column module (MB: 2215457832):
Dr-side SAM - Driver signal acquisition and actuation module (MB: 2215457732):
REAR SAM - Rear signal acquisition and actuation module (MB: 2215454832):
- Fault: Error: Kofferaumlicht Links: Open load or short circuit
- Code: 0090B1
System diagnosis (MB: 2215408945):
CGW - Central gateway (MB: 2215408945):
11. Chassis:
ABC active body control (MB: 2215450532):
12. Body:
DS-LF - Left front dynamic seat (MB: 2168204326):
- Code: 009010
DS-RF - Right front dynamic seat (MB: 2168204326):
PPAMKS - Pneumatic pump for active multicontour seat (M40/1) (MB: 2218001248):
ESA-FL - Electric seat adjustment front left (MB: 2168200026):
DCM-FL - Door control module front left (MB: 2168207726):
- Fault: The mirror heater has Open circuit.
- Code: 00900A
DCM-FR - Door control module front right (MB: 2219011200):
